Order Farmall Cub Parts Online
Cub Carb Settings
BillA
11-25-2005 15:33:45
On a '52 Cub what would be the correct setting on the air mixture screw? Cleaned the carb and the screw was set at about 3.75 turns out and that just seemed like a little much. I am ordering a manual, but need this info now if someone knows.
Thanks for any help
Ken C.
11-25-2005 16:28:23
 Re: Cub Carb Settings in reply to BillA, 11-25-2005 15:33:45
The idle adjusting screw should be set at one turn out. The other screw is the throttle stop screw, which you set for your engine idle speed.
Ken C.
