Re: F-12 Steel Lugs
Pale Rider
11-25-2005 19:12:35
third party image
I wouldn't expect you to have difficulty in finding steel lugs for it. They were common to several other models as well. They came in a couple of differing lengths so you'll have to decide what you prefer. Make sure you also specify the width. I needed only one and I DID specify the width. Sure enough when it arrived it was wider than the others. I had easy access to a porta band saw at work and did a slick job of cutting it to proper width and cleaning it up. It bolted up the same and you'd never know which one it was. But I wouldn't want to to it for a whole set even with a porta band.
The cost may be more than you are hoping for for two reasons. They are going to weigh quite a bit to ship presumably in something like several five gallon buckets and they are likely going to be a dickens for someone else to remove from their existing wheels assuming rusty bolts. I was very careful and slow at taking mine off for rolling it around during restoration. Even after soaking them in Break Free and heating them with a torch there were some that still snapped off the 5/8's bolts that held them on. I purchased some new square head bolts for them but of course 5/8's square head bolts were a hard to obtain item and I had to buy a box of 25. Make sure you make it clear to whoever you are purchasing them from that they send along the bolts along with the lugs and save yourself some grief even if you can only use a portion of them.
I would try getting ahold of Nebraska Cowman or the Steel wheel Ranch and asking them first.
PurdueAg
11-25-2005 19:23:10
 Re: F-12 Steel Lugs in reply to Pale Rider, 11-25-2005 19:12:35
Thanks for the info. I'll have to do some research to see what width I need for the wheels I have. Depending on where I find a set, it might be cheaper to pick them up in person...
Pale Rider
11-25-2005 19:59:47
 Re: F-12 Steel Lugs in reply to PurdueAg, 11-25-2005 19:23:10
If I remember I'll check what I have in the morning and repost tomorrow evening. The lugs are not the full width of the wheel. They alternate from going from one edge to the other.
