serial number Question
3501Mike
11-26-2005 10:45:23
My serial number tag on my Farmall H is just a plain metal tag with nothing else on it but 28846AJ .So I was thinking it's a 53 The battery is under the seat so I was thinking a Super H . Then this morning I read a post that the serial number is stamped under the number one spark plug that number is 358067R1 so now I have no idea what it is . Thanks for any help Mike
CNKS
11-26-2005 18:33:46
 Re: serial number Question in reply to 3501Mike, 11-26-2005 10:45:23
I agree with DWV. You have a late 1954 Stage 2 Super H with a distillate engine (A) and a Rockford clutch (J). Last SH serial was 29285. Thus there were only 439 more Super H's built after yours.
3501Mike
11-27-2005 12:22:58
 Re: serial number Question in reply to CNKS, 11-26-2005 18:33:46
Thanks all of you for your help . The reason I wasn't sure of what she was is at one time she had been repainted and a H decal was put on .Everything I read here on the forum made me think I had a super . Thanks again for all your help Mike in Colorado
DWV
11-26-2005 14:50:35
Believe its a 54 SH, originally distillate fuel.
The starter should be mounted with 3 bolts and to
left side of tractor from center line,versus right
side for stage 1 SH.
Pat H
11-26-2005 14:07:18
Your block should be a C-164 and if my math is close your block serial number would be approx 33565. This number would be stamped in a raised "boss" just below the head and in front of the oil filter. Would help if we could see some pics. What state do you live in? Pat from Wisc
El Toro
11-26-2005 11:50:07
That may be the casting number for the head that you posted. Look under No1 plug for another number. If it's an H it would be a 1940 tractor.
Would be a 1954 if it's a Super H. Hal
3501Mike
11-26-2005 12:55:15
 another number Hal in reply to El Toro, 11-26-2005 11:50:07
Hal, I found another number on a small raised area on the casting it is 33570A It was a little to the right and below the number one sparkplug
Pat H
11-26-2005 18:58:25
 Re: another number Hal in reply to 3501Mike, 11-26-2005 12:55:15
my calcs were pretty close - got me within 5 engines of yours. e-mail some pics sometime - would like to see it. my email is superh@maqs.net
I've got a few super H's. IMHO best tractor ever built. Pat in Wisc
El Toro
11-26-2005 15:55:09
From reading Pat's posting I think you have a Super H. Hal
3501Mike
11-26-2005 12:47:38
 Re: serial number Question in reply to El Toro, 11-26-2005 11:50:07
Thanks Hal , I'll get to the bottom of this yet
