ground and charge
tractor-ernie
11-26-2005 11:59:13
I have a '57 IH 130. It has been converted to 12 volt. It doesn't seem to want to charge (new battery and alternator). I noticed that the guy who converted it has it set up for negative ground . Is that correct or doesn't it matter? When I do get a slight reading on the ammeter, it reads negative. It started all Summer but in the cold it tries but no go.
old
11-26-2005 14:03:30
 Re: ground and charge in reply to tractor-ernie, 11-26-2005 11:59:13
Since you ask about the ground. Have you ever put the battery in with + ground, if you did your new alternator is toast. Alternators work only on - ground unless you have a brit alternator which you probably don't have. If you put a battery in with + ground the moment you hook the battery up you fry the alternator diodes.
El Toro
11-26-2005 12:39:19
With the engine running at 1/2 throttle check your battery voltage across the battery terminals using a dc voltmeter. Should be around 13.5-14
volts. If it is charging ok, you may have a battery drain discharging your battery. Hal
Dellbertt
11-26-2005 12:07:52
Pos/Neg doesnt matter to the starter but it matters to everything in the charging circuit.
You need to take some basic dc readings to see where you are.
