Mini Alternator, on a H.
Andrew Z
11-26-2005 12:27:52
Does anyone know where I can get one of those mini alernators that will fit under the hood of an H. Thanks Andrew
Jim in NC
11-26-2005 18:13:49
 Re: Mini Alternator, on a H. in reply to Andrew Z, 11-26-2005 12:27:52
I used a full-sized GM alternator with built-in voltage regulator, cost about $35 to $40, with the idler pulley as the belt adjustment. I bought the idler pulley, one used on a lawnmower deck, from the local hardware store. It all worked great. I used the archived photos on this site.
Tim Shaw
11-26-2005 15:49:07
I used a nippondenso from an early 80s Toyota Tercel on our Super H. It fit under the hood alright but it is a close fit. I fabricated my own bracket and belt adjuster and followed Bob M's diagrams and everything worked out great.
Andrew Z
11-26-2005 14:45:21
Thanks guys for the help!
Would anyone know the belt that I would need? Thanks again Andrew
Tim Shaw
11-27-2005 11:11:11
 Re: Mini Alternator, on a H. in reply to Andrew Z, 11-26-2005 14:45:21
I used the original belt.
old
11-26-2005 14:05:07
Ask for an alternator for a 1986 toyota pickup up truck. They fit real nice put one on a cub last year and thats even tighter the an H
El Toro
11-26-2005 12:44:04
Do you want 6 volt or 12 volt alternator. The 6 volt comes in either positive or negative ground.
Hal
Andrew Z
11-26-2005 12:52:27
 Re: Mini Alternator, on a H. in reply to El Toro, 11-26-2005 12:44:04
I got a 12 volt alternator on there now but its not charging and it does not let me shut the hood all the way. So I guess If I have to get a new one want to get one that will fit. Thanks Andrew
little john
11-27-2005 04:40:52
 Re: Mini Alternator, on a H. in reply to Andrew Z, 11-26-2005 12:52:27
I have a Japanese alternator still in the NAPA box if you decide to go that route, but the Delco will fit. jwc1934@aol.com
El Toro
11-26-2005 14:21:58
I think they use the Delco 10SI 12 volt alternator
on these tractor conversions. You can go to this web site to see a picture of the 10SI and
installation instructions. You can click on page 5 of this forum and find Mark Herbert's posting on a Super A alternator. Click on Bob M's response. He recommends the 10SI too.
Link
There's a Hitachi alternator model 14231 that's used by some of these tractor owners. It's available at NAPA p/n 2138130 for $50.00 exchange. It may be smaller too. Go look at them in your local NAPA auto parts store. Then make your choice. Hal
