F-20 is runing better thankyou !!
J Muehring
11-26-2005 20:12:56
Ive been at witts end with rough runing , hard starting old F-20 so I tried Autolite 3077 xtra reach plugs. It started on 3rd pull and kept runing instead of dying like it useally does. It also ran smooth as I advanced the spark, that was the real test. I might not install new points and condenser now. Does anybody want some used champ W-18 plugs for paper weights? Thanks very much for GOOD TIP.
Pacef20s
11-27-2005 17:15:55
 Re: F-20 is runing better thankyou !! in reply to J Muehring, 11-26-2005 20:12:56
The Autolite 3077's made a big difference on my F20. I wouldn't necessarily suggest using them if your going to be working the tractor, though. They can be found on Ebay. Regards, Roland
martin reece
11-27-2005 15:37:42
I am using Champion W-18 plugs and have the same problem Where did you get the Autolites and were they expensive? Thanks Martin
J Muehring
11-28-2005 17:31:37
 Re: F-20 is runing better thankyou !! in reply to martin reece, 11-27-2005 15:37:42
Martin, I ordered my 3077 plugs through O Rileys auto parts for under two bucks ea. I went back and got four more for the F-30. The hardest work my 20 does is plow a big garden.
