HELP! M won't start after installing voltage reg.
Granger
11-27-2005 11:12:14
A couple of weeks ago (after I used Bob M.'s trouble shooting guide) & discovered that I had a bad voltage regulator, I ordered a new one & replaced it. After I replaced it,I jumpered between the "BAT" & "GEN" terminals at regulator & started. It started right up & I let it run for a while & the ammeter showed a charge, which it did not before. Well, I went to start it today & at first it started right up & then after a little while, it died on me. When I went to start it again, it was DEAD. I turned on the lights & it still shows a discharge, but when I push on the starter, NOTHING happens. Any ideas out there was is happening or I should check? Thanks for all the help.
CNKS
11-27-2005 11:24:48
 Re: HELP! M won't start after installing voltage r in reply to Granger, 11-27-2005 11:12:14
First, charge the battery. While you are doing that, remove all the connections to the battery, ignition switch, starter switch, etc and clean them; pay particular attention to the ground connection. With 6 volts it does not take much corrosion to keep the starter from turning over. Battery cables should be no less than 2 gauge, bigger if you can find them. All this assumes that your wiring is correct. Possibly you could have messed up the generator or regulator during the changeover process causing one or the other to quit working. Always best to disconnect the battery before working on anything. Be sure to follow Bob's diagrams exactly.
