756 hyd problem
Idealelec
11-27-2005 16:23:37
My 756 has no power steering or brakes.the warnig light is flashing.The tractor had been sitting for 3 mos. I had the pump off it looks ok ,filled it w/oil & replaced it.still nothing.Loosened the oil cooler lines &the brake line,no oil at either.Is the pump shot? Can it be rebuilt? Thanks For the help.
the tractor vet
11-27-2005 18:17:46
 Re: 756 hyd problem in reply to Idealelec, 11-27-2005 16:23:37
Just what pump did you have out the one in the rear housing or the one in the speed trans behind the MCV ????? . Make sure that the Hdy . filter is good if there is a question as to it's clean or not replace it. with a new gskt. make sure that the hdy. oil level is at the full mark and run the tractor at around 2100 RPM and turn the steering wheel to the left till it pick up prime . sometimes it may take a bit . if it does not pick up prime then well maybe then it is time for a new pump.
