taking off m radiator
farmallkid04
11-27-2005 18:14:16
how many bolts is there to take off a sup. m radiatar and where are they at?
Haas
11-27-2005 18:35:05
 Re: taking off m radiator in reply to farmallkid04, 11-27-2005 18:14:16
Two at the bottom,(If still original, these will have castle nuts and cotter pins). They are stud bolts that screw into the bottom of the radiator, so they may unscrew out of the radiator. There is a brace at the top attached to the gas tank support near the oil/temp gages. Fan shroud needs to come off, which is held by several small bolts. Also, you have to remove the steering shaft which goes through the top tank of the radiator.
Don L C
11-28-2005 09:35:37
 Re: taking off m radiator in reply to Haas, 11-27-2005 18:35:05
Differnt tractor, he said Farmall M not a 300----
Add this to HAAS'reply...Disconnect steering rod at oil7 water guage location...remove large plugat front of stearing box,WATCH OUT for oil!...unscrew rod clockwise and pull it out the front WATCH OUT more oil...this is 80/90w gear oil...
Nat
11-28-2005 10:23:48
 Re: taking off m radiator in reply to Don L C, 11-28-2005 09:35:37
Different tractor, but same removal method. A 300 is nothing more than a miniature M with extra stuff bolted on it, and a different hood.
IHPRIDE
11-27-2005 18:19:28
I restored a Farmall 300 and there were only two bolts underneath the frame, then you disconnected the hoses and she comes right out.
