41 H HAS NO POWER
JON ARCHAMBAULT
11-28-2005 08:03:17
I HAVE A 1941 FARMALL H, IT START AND RUNS OK, BUT HAS NO POWER. IT CAN BEARLY MOVE ITSELF IN 1ST GEAR. ANYBODY KNOW. HELP!!!!
P.S. JUST PUT NEW HEAD GASKET ON AND PISTONS AND RINGS LOOK GOOD.
THANKS
JON
El Toro
11-28-2005 10:23:53
 Re: 41 H HAS NO POWER in reply to JON ARCHAMBAULT, 11-28-2005 08:03:17
You may need to open the main jet adjusting screw
several turns CCW. This will increase the gas to the engine. Set the valve lash to .020" cold. Hal
JON ARCHAMBAULT
11-29-2005 09:45:35
 Re: LASH in reply to El Toro, 11-28-2005 10:23:53
Hal,
How do you set the valve lash?
Pull valve cover and adjust the nut on valve springs?
THANK YOU HAL FOR YOUR REPLY AND HELP
JON
Nat
11-28-2005 10:13:28
Sounds like a governor issue to me. Even if the engine is totally totally worn out, it would still have enough power to move the tractor in 1st through 4th. Beyond that, it wouldn"t have enough compression to even start.
Did you take the carburetor off? The connection between the carb and governor is kind of tricky to get right.
JON ARCHAMBAULT
11-29-2005 09:15:42
 Re: 41 H HAS NO POWER in reply to Nat, 11-28-2005 10:13:28
Nat,
I did take the carb & gov apart as part of replacing the head gasket.
What is tricky about connecting the carb and governor back up? I dont understand how the governor even works. Should I just buy a manual?
THANK YOU FOR YOUR REPLY
JON
Dellbertt
11-28-2005 09:32:03
I agree with old. You need to start from square one with headbolt torque, valve adjustment, timing etc.
old
11-28-2005 08:28:09
Well that could be a number of things. Did you retorque the head after you had woarmed it up?? Are all the valves adjusted right, when you pull a head you need to readjust the valves. Are all the push rods for the valves where they should be, seen them fall out of place and then you will have no power. Do you maybe have a vacuum leak in the intake, or did you maybe get the carb on wrong and the govner isn't opening the carb up when it needs more gas, seen that also. Just a few of a long list that could be your problem. Also did it run right and have power before you changed the head gasket? Also is you fireing order correct that will also kill your power.
