IH 354 hydraulics help, please
genep
11-28-2005 10:29:37
The lift on my 354 leaks down badly. With a medium duty box blade on it it will "hic-up" every second or two. With the engine off it will drop to the ground in a about a minute. I disassembled the hydraulics this week-end expecting to find something evident because it drops so fast. With the help of a IH Blue Ribbon publication I identified the valves/seals that lock the pressure when holding the lift up. None of the seals, balls, etc show any nicks, cuts, or breaks that I would expect to see from such a rapid leakdown. Can anyone give me some ideas on where to look for my problem? My email is open and any suggestions are welcome and much appreciated.
thanks,
Gene
Bruce Nuesse
10-12-2006 15:26:45
 Re: IH 354 hydraulics help, please in reply to genep, 11-28-2005 10:29:37
Mine does the same thing, have you had any fixes for it yet?.
David O'Lone
02-19-2006 05:52:14
Do the seals on the lift piston look good and the cylinder itself. I'm wondering also is the relief valve assembly healthy??
