Farmall H/M Belly Pump
JohnG(TX)
11-28-2005 11:28:41
What parts will interchange between the H & M belly pumps? I have several M's with pumps, and can get an H pump for cheap. Is there anything in the H pump I can use? Thanks.
JG
john d
11-28-2005 15:53:11
 Re: Farmall H/M Belly Pump in reply to JohnG(TX), 11-28-2005 11:28:41
The plumbing parts coming out of it, the cap on the filler pipe, and possibly the lever that is moved by the control rod. Beyond those parts and some misc. bolts, likely nothing. I don't know if the relief valve inside is the same, or not.
