Super C...plugs hard to get out...
plinker
11-28-2005 14:42:51
All my sparkplug sockets failed to get down into the plug wells deep enough to grip them. Finally I found a socket that had a thin enough wall to get in there. However, one of the four plugs apparently was installed without the washer, and thus was set a tad deeper into the well....and I can't get my socket to get a grip on it. Is there a specific tool that seems to solve this problem?
fluggie in IA
11-29-2005 07:59:53
 Re: Super C...plugs hard to get out... in reply to plinker, 11-28-2005 14:42:51
You must have AC plugs! I tried to install AC's in my SC and found out without a special thin wall socket, you can't tighten them so I went back to the dreaded Champions.
the hex area of the plug is lower on an AC than on Champions so the socket won't grab all the way to the bottom to tighten.
I'll get a thin wall later for next time.
ACHodges
11-28-2005 21:28:55
Never had a problem. Use a sears 12 point deep socket. I did have a problem with a moline, turned out to be years of crud compacted around the holes, had to chisel it out with an awl.
Roger46
11-28-2005 19:44:02
I have never had trouble getting out the spark plugs on my A, B, Super C, or Super H. I always just use a 7/8 deep socket, 1/2 inch drive. I just took out 12 spark plugs on these tractors getting them ready for winter storage. Roger
Keith-OR
11-28-2005 17:38:26
Geees, I can't see what is so hard about getting out spark plugs. I just use thin wall deep 7/8 socket 3/8 drive. I have no problem getting it on the spark plug even with old dirt and grease on and around the plug. But I always use air hose and blow noozle to clean out around plug before I remove it as to not get any dirt into cylinder...
Keith & Shawn
plinker
11-29-2005 14:23:44
 Re: Super C...plugs hard to get out... in reply to Keith-OR, 11-28-2005 17:38:26
Geeeee z.....thanks for all the tales of how you've never had a problem...I hadn't either until this one plug. I appreciate those tips on how to resolve it.
Joe in VT
11-28-2005 17:37:39
Last summer I was searching for a 7/8's sparkplug socket to get the plugs out of my Super C....
no body had one ! I went to my local Snap On guy
he sold me one ...I think it cost me $25 bucks for one socket !! but it works great fits right in with no problem .
Joe
plinker
11-28-2005 15:18:55
The chainsaw sparkplug wrench sounds worth a try....I've always got it with me...and if not, off to the grinder.
Thanks
Yugrotcart
11-28-2005 14:58:15
You need one of those light sockets like what comes with a chain saw. Either that or take the grinder to the socket that you have.
Bob
11-28-2005 15:48:55
 Re: Super C...plugs hard to get out... in reply to Yugrotcart, 11-28-2005 14:58:15
Must be a heck of a big chainsaw if you need a 7/8" sparkplug socket for it ;-)!
Yugrotcart
11-28-2005 16:03:22
 Re: Super C...plugs hard to get out... in reply to Bob, 11-28-2005 15:48:55
I thought everyone owned a chainsaw as big as mine..... ..... ok, not specificly a chain saw one, but one of that style, also used on outboard motors..... ..... ...:)
CJ-maybe
11-28-2005 14:55:11
Dad made one just for that.Ground a taper on the outside of a regular socket till it would clear.I think it was only the first 1/2-3/4".
terryjd
11-29-2005 01:15:12
 Re: Super C...plugs hard to get out... in reply to CJ-maybe, 11-28-2005 14:55:11
I use a motercycle socket on mine, think thats what it is anyways. It is just the socket on the bottom then has a hole through the center at the top that you put a screwdriver, long thin bolt, punch whatever through to use to twist it. It is very thin walled socket type thing.
plinker
11-29-2005 14:19:44
 Re: Super C...plugs hard to get out... in reply to terryjd, 11-29-2005 01:15:12
Right...the chainsaw wrench would be for the smaller plugs I guess...I was thinking the same, re the cheap toolkit type with the hole for the screwdriver ()motorcycle type)...might slip in there. As mentioned above, maybe the problem is the plug type where the gripping is done just a shade lower on the plug body, making it harder to get the socket in deep enough without that washer holding it up a smidgen.
Thanks.
