Weight of H rear wheel ?
riverbend
11-28-2005 15:54:57
What does the cast iron part (pn 6194DD) of the rear wheel on an H weigh ?
Were there two different sizes of rear wheel weights ? The parts book says that they weigh 145#. The guy at the salvage yard thought that they were about 80# a piece.
Thanks
Greg
Dellbertt
11-28-2005 20:49:12
 Re: Weight of H rear wheel ? in reply to riverbend, 11-28-2005 15:54:57
I have the half circle on my 300U"s and the same thickness full circle on my H. BUT, in the H parts manual it only shows full circle that are fairly thin compared to most. I think the original H rear weights were thinner than the ones commonly seen. Anyone with more info?
farmallhal
11-28-2005 16:11:04
Greg, the salvage yard person might be talking about the half circle wheel weights. I have them on a M tractor and it takes two for each side. Same thickness but only cover half the cast wheel. Much easier to work with then the full circle ones as they are half the 145# weight. Don't know about the weight of the 6194DD cast wheel as I have never had one off. Hope this helps. Hal
