Advice on cleaning out trans/diff cases
MAC in TX
11-28-2005 19:52:54
Hi all, I am restoring a 1940 Farmall H. The old stinky oil/some water was drained out of trans/diff cases. What would be good to put in there to clean up the inside without harming any seals.
Thanks.
Doc Larry
11-29-2005 05:37:29
 Re: Advice on cleaning out trans/diff cases in reply to MAC in TX, 11-28-2005 19:52:54
When I flushed mine with diesel all the seals started leaking. But when I refilled with 80w90 all the leaking stopped....
Also, I drove mine around for an hour or so in cool weather but should have run it a little more to really clean things out better - I say this because I had the cover off a few weeks later and saw what was still left inside....
Larry
gene bender
11-29-2005 04:14:13
Drain it. Then put bunch of diesel fuel and drive it around and drain again mite even want to do this twice. I have sometimes put an air hose and turned on real low pressure to make the fuel "boil".
Jonesy
11-28-2005 20:40:40
Dont use degreaser solvent if your not going to replace the old leather seals. I made that mistake by flushing a tranny on a 130 with 10 + 1 degreaser then filling with oil. Didnt notice it till the next day when all the oil was on the shop floor. Good thing it wasnt an M (15 gal worth). The best way I know without taking the top cap off is to remove the pto and drag it all out with some rags. WD 40 is also a good degreaser and a great hand cleaner.Good luck, its all a mess.
Phlogiston
11-28-2005 20:38:44
This advice came right from an IH mechanic. He said to drain out what you have in there, fill it with kerosene and take it for a drive. Drain that out and then fill with the proper fluid. He added that you should never do this with an engine, but it works great for the rear end. I think you will be surprised at what comes out with the kerosene. Yes, I have tried it and it works good.
Phlogiston
