Order Farmall Cub Parts Online
Ajustable tie-rods for a 1949 Farmall Cub
George the farm
11-29-2005 00:51:18
I have a 1949 Cub with the ajustable tie-rods and they are froze. Trying to free them but not having any luck. Tryed heat and still no luck. Anyone have any suggestions as to how to free them? They should slide out of the tube. I'm trying to move the axle out one hole and need to adjust it. Thanks for any advice you can give. George
gene bender
11-29-2005 05:31:06
 Re: Ajustable tie-rods for a 1949 Farmall Cub in reply to George the farmer, 11-29-2005 00:51:18
Are you sure that your axle is not a fixed one as some were notadjustable just like some on the A were fixed.
George the farmer
11-29-2005 16:52:25
 Re: Ajustable tie-rods for a 1949 Farmall Cub in reply to gene bender, 11-29-2005 05:31:06
Gene, they will expand ( slide in and out) the axles. Already moved them out one noch. George
gene bender
11-29-2005 17:03:12
 Re: Ajustable tie-rods for a 1949 Farmall Cub in reply to George the farmer, 11-29-2005 16:52:25
OK i have had the problems also used wd-40 and a small hammer and tapped all along the length to get some penetration of the wd and finally got them loose but no fun at all. I have a friend who will let them soak submerged in water for weeks and usually they will come apart. His theory is that water rusted them and if you can soak long enough the water will free them. good luck like i said no fun at all.
George the farmer
11-30-2005 10:25:03
 Re: Ajustable tie-rods for a 1949 Farmall Cub in reply to gene bender, 11-29-2005 17:03:12
Gene, appreciate the information, will give it a try. Thanks again, George
Slappy
11-29-2005 04:45:41
Hal has the right idea - some type of penatrating lubricant and some time and it should free up. I like Kroil as well as PB Blaster. One thing I might add is that the rods must be straight or they will bind. I had one that I had cleaned and greased. It looked straight but aparently had a slight bow and it was a bear to get apart - I can't imagine what it would have been like if it was rusted as well.
El Toro
11-29-2005 04:09:06
Spray them with Kroil & let that soak. Then use more heat. Hal
PS: They probably haven't been moved since 1949.
