Zenith Rebuild-drip plug / neoprene seals
Kendog
11-29-2005 11:16:33
1. The parts catalog shows a felt & inner washer within the drip plug of the carb. I can see there is nothing other than the outer cover with the pinhole. Issue? Should a rebuild call for a repacking of a breathable material or plug it? It would offer an air leak.
2. The neoprene throttle shaft seals installation instructions are not clear. Do you install them with the 'open' edge to the INSIDE or OUTSIDE? Based on the principals of vacuume, it would seem the open edge of the seal would be to the outside. AND do you lube them with dielectric grease? Thank you.
