steering box oil
joe/mass
11-29-2005 11:58:09
Whats the correct oil for the steering box for my 130. Operators manual says Amplifier Transmission Lubricant Additive.
Thanks in advance..Joe
Billde
11-29-2005 19:46:10
 Re: steering box oil in reply to joe/mass, 11-29-2005 11:58:09
John Deere corn head grease works well in leaky gear boxes too. Don't worry, your RED tractor won't mind, mine don't.
Hugh MacKay
11-29-2005 12:19:22
Joe: Farmall 130 steering box should use gear oil 80W or heavier. If it leaks, drain the oil, put a grease zerk in the fill to level port. With gun grease pump until grease comes out oil fill hole. Moly grease is best. It will work good even in cold weather. Best of all, the tractor will stay clean.
joe/mass
11-29-2005 18:20:59
 Re: steering box oil in reply to Hugh MacKay, 11-29-2005 12:19:22
Ok, thanks I will try that...
As always thanks to everyone who reply's to this forum, it's been a great help...Joe
