Oil seal on brake shaft on H IH
Richland
11-30-2005 08:58:27
Dealer sold me a single seal for this shaft and there is two seals on tractor. Have they gone to a single seal or did dealer give me the wrong seal.
H IH with band brake.
Richard
arod
11-30-2005 15:49:19
 Re: Oil seal on brake shaft on H IH in reply to Richland, 11-30-2005 08:58:27
common just to double up. when I replaced my farmall m pto seal, how many did I remove? two! I just put the new ONE replacement on and it worked great.
Haas
11-30-2005 09:10:11
All of the seals now are much smaller than the original ones in the old farmalls. Some folks like to use two of the new seals, but I have not found that to be necessary. If the surface the seal runs on is good, one will be sufficient. The new seals are of a much improved material.
John *.?-!.* cub owner
11-30-2005 19:21:02
 Re: Oil seal on brake shaft on H IH in reply to Haas, 11-30-2005 09:10:11
Alos, putting in 2 is a waste of money. The one away form the oil will soon wear out due to no lubrication.
Haas
12-01-2005 06:45:06
 Re: Oil seal on brake shaft on H IH in reply to John *.?-!.* cub owner, 11-30-2005 19:21:02
Some folks say to put gease between the two seals to help keep the outside one lubricated. But I agree in general that using two is a waste of money. If the inside one happens to leak a little, then the outside one will get lubed from that. However, better to spend your money getting the shaft surface in top condition with a speedi sleeve or other method.
