806 Vs. 706 wheels
Roytex
11-30-2005 09:20:49
I have an 806 and 706 that I want to swap front wheels. I want to put the front wheels and hubs on the 806 that are currently on the 706, will this work or are the spindles a different size? Thanks!
Dellbertt
12-01-2005 06:58:01
 Re: 806 Vs. 706 wheels in reply to Roytex, 11-30-2005 09:20:49
They must be different sizes or it seems to me you would just change the tires.
K.B.-826
11-30-2005 15:46:02
Yes, it will work. The 6 and 8 bolt hubs will interchange on anything from a 560 to a 3688, and probably the 5088 series too. The bearings are the same for either hub. I think the 460, 544, and 656 might have a smaller spindle, but I'm not 100% sure on that.
Dellbertt
11-30-2005 11:09:44
Look in the parts book and see if the parts are the same number.
ejr-IA.
11-30-2005 09:27:05
Yes they should if their both IH hubs.You must have 8bolt on one and 6 bolt on the other.Other wize why change.
Roytex
11-30-2005 10:19:01
 Re: 806 Vs. 706 wheels in reply to ejr-IA., 11-30-2005 09:27:05
Exactly, I cannot just change out the wheels, so I want to change the hubs.
