Super C Rear Drain Plug
Jon R.
11-30-2005 14:05:50
Can anyone tell me where the drain plug for the rear end is on a Super C. My cousin said that is on the side, but I couldn't find it. Any help would be appreciated. I want to get the oil and any possible water out of it before it freezes this winter. I am going to have to move it, and I don't want to tear something up. Thanks
BobG in Va
11-30-2005 14:15:22
 Re: Super C Rear Drain Plug in reply to Jon R., 11-30-2005 14:05:50
I believe (if memory serves me right) that it is directly in the center of the differential. I believe it is a plug like the fill plug (that's next to the gearshift). A 1/2 inch 4 sided breaker bar should work. Make sure you have at least a 5 gallon bucket with you, 'cause it will have at least that much in it, plus any water. Refill with a tad under 5 gallons of 80/90 gear oil. The level plug is on the right side of the differential (facing from the rear) about halfway up. Should be smaller (1/4 inch) plug. Good luck and I hope my memory is correct. BobG in VA
Peabody
11-30-2005 18:09:15
 Re: Super C Rear Drain Plug in reply to BobG in Va, 11-30-2005 14:15:22
BobG, your memory IS correct, the plug is pretty much dead center of the bottom of the differential case. The only reason it would not be obvious is if you've got a lot of greasy crud built up under there. A little scraping and cleaning should expose it.
Jon R.
11-30-2005 14:25:34
Thanks, I'll see if I can find it.
