Farmall M Just won't Start!
Keith M
11-30-2005 14:46:45
Hi, I have an old Farmall M that I got after my father passed away. The tractor has been in a shed for the past 3 years. My uncle told me that it ran fine before it sat. I have put in new plugs & cables, distribior cap, points, and cleaned out the carb, put new gaskets on the carb, checked the fuel line, drained out and replaced the gas. I get fuel to the carb. I also get a spark at the plugs. I have a manual and adjusted the carb according to that. I checked the butterfly throttle, that too works. The fuel isn't getting to the spark plugs. The plugs are always dry. I'm stumped and out of ideas... Does anybody have any suggestions? I so badly want to fix my dads tractor myself! PLEASE ADVISE! THANKS!
Pappy
12-01-2005 17:47:17
 Re: Farmall M Just won't Start! in reply to Keith M, 11-30-2005 14:46:45
Did you for sure get the throttle rod re-inserted into the carburetor properly? Thats the rod that opens and closes the carburetor butterfly from the governor. It is not hard to miss this.
Nebraska Cowman
12-01-2005 05:45:58
Well, if the plugs are staying dry you are NOT getting fuel. Try spraying starting fluid in and see if it will run on that and you can eliminalte any spark issues. Work on the fuel problem first.
Cityboy-McCoy
12-01-2005 04:59:39
I had the same situation with a 140 that had sat for a long time - no gas to the plugs. Choked it until gas flowed out on the floor.
Finally took out the plugs and used an old syringe to shoot a little gas in each cylinder. It fired right up and quit; but then the choke was effective and she fired right back up. Been running fine ever since.
mike
El Toro
12-01-2005 04:08:40
After squirting oil into those cylinders run a compression check on the engine & compare the readings. Should be close to one another. Hal
Dale Hinthorn
11-30-2005 19:56:00
all the items that are listed looks to be good suggestions but if you'll put a little oil in the cylinders to bring up the compression that may be all you need . I had a jd 1010 that had sat for several years and trying to get it started was a big deal.I had changed ever thing to no avail until I realized no compression I put transmittion oil in the cylinders and pull started it the first time and it has not failed to start sence
Mel in OR
11-30-2005 18:51:21
Keith,
I have had your same situation with an M my Dad gave me which sat in my garage for years. I'm guessing you don't have plug wires or distributor components put back correctly effecting timing. Study that. One time I put the point cap on 180 degrees off. Hate to admit those things. M's are very forgiving if they have gas and spark but timing has to be correct.
Will Sick
11-30-2005 18:33:10
I had this happen to me on A super that I bought .It too had been sitting. I tuned out that ther was dirt in the bottom of the carburetor and gas couldn't get thru to th run jet.It is apparant that if the plugs remain dry that gas isn't getting thru.
Dixieland
11-30-2005 17:35:02
I"ll bet you a dollar against a hole in a doughnut that you have the firing order wrong. The firing order is 1-3-4-2 from front to rear. Check it out and let us know.
Good luck,
Rex
old
11-30-2005 16:41:30
If it sat that long fill the cylinders with tranny fluid and let it sit a day or 2. Be sure to put the plugs back in so dirt etc don't get in to the cylinders. Then after it has set a day or so the pull all the plugs and crank the engine over to clear the cylinders. Put the plugs back in and see if it will start. You probably have stuck rings and that causes low compression and that cause lack of vacuum on the intake.
Rich Griffin
11-30-2005 16:28:19
Pull all Spark plugs out,put motor oil in squirt can,squirt 4 times into each cyl,crank over quite often,install plugs. This is my remedy. It builds up compression and vacume so to suck gas and fire.
Dave in CT
11-30-2005 16:00:35
This is a confession. I had a no-start condition with a more recently run H. The tank had run dry so I filled it and still got no start after enough cranking to get the carb primed - even put my hand over the intake of the carb to administer the fullest choke - ouch. _Had_ to get it going in a hurry as, like most of us, many other tasks were waiting. Shot a little of my brother's Pyroil starting fluid in the intake and at least got it to run a short while. After a couple of repetitions of that it ran continuously and restarted fine. This is the first time I've used any starter fluid. Usually I want to get down to why it's not acting normal. In short, I'm encouraging you to CHEAT. Maybe that'll get enough firing going on you can figure out what's wrong. I'm still guessing on my problem.
arod
11-30-2005 15:44:47
fuel problem... well perhaps the carb has a stuck float, or you installed the needle valve upside down.
Janicholson
11-30-2005 15:21:14
Fixing everything at once is problematic, if one of the fixes is incorrect there are now two issues ETC! However! I would pull out the sparkplugs and (using a squirt oilcan filled with 2stroke mix gasoline I would use one squirt in each cylinder then put in that plug finger tight. Then tighten all the plugs. Crank the tractor (neutral etc.) to see if it starts.
If it starts and dies, you have a fuel delivery problem. if not I suspect either compression (stuck valves) or spark timing/firing order. 1342 from front. Looking from rear toward front at the dist. If clockwise rotation of dist.
2 1
4 3
if CCW
3 1
4 2
good hunting, JimN
