Weight of a Super A
Denny Hosmer
11-30-2005 15:45:47
I am considering purchasing a Super A, but I would need to know what size trailer to get. Could anyone tell me the weight of a Super A?
Thanks
Hugh MacKay
11-30-2005 22:49:19
 Re: Weight of a Super A in reply to Denny Hosmer, 11-30-2005 15:45:47
Denny: A bare bones Super will weigh about 2350 to 2500 lbs. I agree with Andrew on the additions and maximum weight.
When selecting a trailer go for 16' deck, size and weight of tractor will not be big factor. Position of tractor on trailer deck makes a big difference. It can make 25 miles seem like a drive with empty pickup, or it can make seem like hell in eternity. After a few short trips you will find the best position.
Robert in Md
11-30-2005 20:19:58
I don't know what a Super A weights but will fit nicely in the body of a 3/4 ton pickup.. I've hauled my super A several times this way. Run in forwards and chain in .
Hugh MacKay
11-30-2005 22:52:15
 Re: Weight of a Super A in reply to Robert in Md, 11-30-2005 20:19:58
Robert: Been there and done that, hard on pickup box to begin with and one must have the ideal spot for loading and unloading.
MnTN
11-30-2005 16:56:57
Denny, I did a quick search through the archives and found a topic that will probably answer some of your questions about hauling a Super A. Copy the link below and paste it into your web browser.
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=farmall&th=471180
Andrew Z
11-30-2005 16:54:59
The weight depends on whats on it. If it has nothing on it around 2800lbs or so. However if its loaded up. Then it could be over 3200lbs. My A weights that. it has front weights aprox.84lbs, rear weights 300lbs, and loaded tires another 300lbs or so. A good tandium axel trailer will do something weigthed for 2 ton to be on the safe side.
Andrew
