farmall bn clutch
pa farmer john
12-01-2005 18:34:43
i have another bn and the clutch pedal appears to be rusted fast. with some help i had pressure put on the pedal as i looked into the inspection port and the push rod attached to the release yoke is flexing trying to move the throw out bearing forward to the clutch, ca the release yoke become rusted fast to the hinge pin ? and if so can i drive out the hinge pin in the upper part of the housing and free it up or should i bite the bullet and just split the tractor? as always your help is appreciated ! john
gene bender
12-02-2005 03:09:28
 Re: farmall bn clutch in reply to pa farmer john, 12-01-2005 18:34:43
Why not bite the bullet and split as the sleeve where the throw-out bearing is probably where it is seized. When you have it split then you can also replace the pilot bearing in the crank. It mite also be the time to replace front seal on the tranny and maybe the bearing too.
