Farmall 400 camshaft gear
Don Brien
12-01-2005 19:16:37
I am rebuilding the engine in a farmall 400 and the cam shaft gear has a chip in one of the teeth and is cracked on another tooth. My question is can i replace just the cam gear or am i going to have to replace all the gears, crank, hydro pump, etc
randy hall
12-02-2005 09:13:44
 Re: Farmall 400 camshaft gear in reply to Don Brien, 12-01-2005 19:16:37
i can get new cam gears for m thru 450. send me an email if interested.
Hayfarmer
12-01-2005 19:31:03
You can replace just the cam gear but I would want to know why it had a chipped tooth and a cracked tooth. Check the other gears to see if they show any signs of cracks or problems.
Mcred
12-01-2005 20:03:25
 Re: Farmall 400 camshaft gear in reply to Hayfarmer, 12-01-2005 19:31:03
can you get new cam gears? If so were do you get them from, I needed one for my M and could not find a new one so we put a used one in.
the treactor vet
12-02-2005 07:22:25
 Re: Farmall 400 camshaft gear in reply to Mcred, 12-01-2005 20:03:25
About thirteen years ago my S/MTA ate the cam gear and camshaft and i was tryen to find just one good cam and gear and was having no luck and was talken to Dan Roberts and he told me that he could get me new gears and he did but the cam i got i ordered in from another suppilerit was one of them imports but Dan sent me a new set of MATCHED gearsets and i am thinking that they were from Perfect Circel . Give Dan a call at 1-800-367-8751.
