806 d Cab heater
stu in njo
12-02-2005 11:12:39
I would like to hook up the cab heater so I can plow snow with it.I need to know were the inlet & outlet lines go it was never hooked up.I would also like to put a tank heater in that loop if I can to help starting. Thanks Stu
Larry806
12-02-2005 19:42:25
 Re: 806 d Cab heater in reply to stu in njo, 12-02-2005 11:12:39
I had 2 806"s still got one I put a in line tank heater on one and it never worked worth a darn. I installed a frost plug heater in the other and it still works fine . I can"t help you on the heater I don"t know what kind your working on most likely it won"t make much difference how you hook up the water lines it just needs to flow through the core
