which farmall?
vinnie
12-02-2005 15:09:16
I am ready to buy a farmall but I need to know which model should I look for. My neighbor advises me to get a model after 1953 cause it will have a fast hitch assemble on it. Any ideas?
vinnie
12-04-2005 18:16:12
 Re: which farmall? in reply to vinnie, 12-02-2005 15:09:16
Thanks for all of the responces. Now I have to find one!
blocks
12-04-2005 17:35:50
hi i have 40 A in the westren UP of Michigan. I have a M there to do jest what you want to do.The soil there is solid red clay no top soil.I us a two bottom trailer plow 14 " .An 11' tandem disk .A 12 ' drag . 6 ' bushog .every thing works good.The M is a real good tractor,parts are fairley easy to find I am told (haven`t had to fix any thing yet only had it two years . good luck Dennis
Ksfarmmer
12-03-2005 06:33:41
Size of your wallet makes a difference as well. The M and H should work fine for what you need. I wonder if a C might be smaller than you want for 50 acres. A pull type bush hog and disk won"t need a fast hitch. I found a Farmall 300 for about the same money that did have the fast hitch. With conversion arms, I can use smaller 3 point equipment. If I was you, I'd find something that you like and not worry so much about what other people suggest.
red joe
12-02-2005 18:14:50
i would recommend a International/Farmall 340, they are right around 35-40hp. We have a 340 utility that we use to plow our driveway, we have a six foot snowblower on the 3-point. and during the summer we have a mower and a couple other things for the three point. Every once in a while we pull a ten foot disk, drill and hay equi[ment with it, it handles it all just fine.
RustyFarmall
12-02-2005 16:46:41
How about a Farmall 340? Same size as a C but newer, and you get live 2 way hydraulics, live PTO, and a fast hitch.
old
12-02-2005 15:13:18
Well you haven't really given enough info for a guess. What you paln on doing with it will matter a lot as far as which tractor to buy.
vinnie
12-02-2005 15:23:10
 Re: which farmall? in reply to old, 12-02-2005 15:13:18
My neighbor has a super c and that seems about the size that I am looking for.
old
12-02-2005 17:09:45
 Re: which farmall? in reply to vinnie, 12-02-2005 15:23:10
Ok now that I know what you want to do then heres a couple more questions for you. Do you want a 3 point hitch or something like one?? From what you say an H or M would fit your bill but didn't come with 3 points but they could be added. The Super C I think had a 2 point hitch which could be made in to a 3 point. You might look at some thing like a super c a 140 2?? or even a 300U. Whith that much land you will find you will probably want more then one tractor. Shot I have 44 acres and own 20 tractors, 15 run and the others are parts.
vinnie
12-02-2005 15:21:30
I want to use ir for brush hogging and disking my 50 acres for deer food plots.
Dave H (MI)
12-02-2005 15:58:42
 Re: which farmall? in reply to vinnie, 12-02-2005 15:21:30
Iffen it were me, given the info provided. I think I would go with an H. It's a little bigger, might be even a tad cheaper but most likely around the same, and more guts. Then there is always the M.....
Dave H (MI)
12-02-2005 15:58:29
