1586 looking to buy part two
rhcon99
12-03-2005 22:48:57
the tractor i found only has 3700 hours hardly any rust a perfect interior new t/a new a/c pump new alternator 3 remotes no leaks that i can see. really need a loder for this tractor also not sure which will fit. the guy is asking 8,000 for this tractor does this sound like a good deal or better or what. p.s also comes with duals cab is immaculate inside
Thack
12-04-2005 09:11:17
 Re: 1586 looking to buy part two in reply to rhcon99, 12-03-2005 22:48:57
The price sounds pretty good. We have a 1586 and it has been a dependable tractor but I would not want to use it as a loader...just my 2 cents.
rhcon99
12-04-2005 17:44:39
 Re: 1586 looking to buy part two in reply to Thack, 12-04-2005 09:11:17
i have had another friend tell me the same as far as not running a loader. why is this such a bad tractor to have a loader on? thanx
Harley
12-03-2005 23:16:48
While not having any personal knowledge about this tractor, this sounds like a lot of tractor for the low hours and the relatively low price for the horsepower. That tractor should be about 150 or so horsepower, and compare that with a new one, and you can see what you could be getting. . Harley
rhcon99
12-03-2005 23:29:15
 Re: 1586 looking to buy part two in reply to Harley , 12-03-2005 23:16:48
its a 161 pto tractor from the info i can find and it seems like a good deal just will be my first international. i think a little more tractor than i need but the price seems right.
dhermesc
12-04-2005 06:44:04
 Re: 1586 looking to buy part two in reply to rhcon99, 12-03-2005 23:29:15
Are you sure about the hours? 3700 hours over 25 years (if it was one of the last ones built) is only 148 hours per year. Thats a lot of tractor for that little use. If it was treated with any degree of care the TA shouldn't have needed replaced at 3700 hours either.
rhcon99
12-04-2005 17:41:01
 Re: 1586 looking to buy part two in reply to dhermesc, 12-04-2005 06:44:04
i was told that it went out because it was always usd in the wrong position. tractor was used to pull a feed trailer and a bailer.
