77 international 284 Hyd Reservor WHERE IS THE LIL
Bobbydrums64
12-04-2005 08:13:23
Do want to seem stupid, Where is the Hyd Tank on my lil 284 what I thought was it was. Was the brake reservor, Is the Hyd in the center where the hyd picks up the blade? in the rear? There is a plug and a vent. The pump was growling this summer when i was mowing, I took the filter off and nothing was in it, I will assume it is dry..how much does it hold???
Thank You
Bobby
Tim Kaiser
10-19-2006 19:00:43
 Re: 77 international 284 Hyd Reservor WHERE IS THE in reply to Bobbydrums64, 12-04-2005 08:13:23
The fill plug and the breather under the seat is the correct spot. Take off the LARGE plug. I have not determined where the level plug is yet, but the drain plug in on the bottom left side under the transmission case. Drain it completly and it takes 14 liters. That is just under 4 gallons. Try 3.5 gallons.
