PULLIN FUEL
VETTE
12-04-2005 13:21:51
I,VE GOT A STOCK "M" THAT I ENJOY PULLING WITH,AND IT DOES PRETTY ON JUST PUMP GAS. FOR THOSE OF YOU THAT PULL IN STOCK CLASS, WHAT KIND OF GAS DO YOU USE? THANKS
ChadS
12-05-2005 07:46:25
 Re: PULLIN FUEL in reply to VETTE, 12-04-2005 13:21:51
Look into E85. 85% ethanol, 15% gas. best fuel you can use in my book. You will have to add more gas tothe mix to dillute the ethanol, but it makes power, holds torque longer, and use a resource that comes from the farm. Have any of you guys seen the Dukes of Hazzard episode, where Jessie enters his shine car in an experimental fuel contest??? Love that whiskey. HAHAHA!! Well, I used to that is,,, LOL! ChadS
VETTE
12-05-2005 07:52:53
 Re: PULLIN FUEL in reply to ChadS, 12-05-2005 07:46:25
I HAVE READ DIFERENT COMMENTS ABOUT THE E-3, BUT I DON,T THINK IT S AVAILABLE HERE IN EAST TX. AT LEAST, I HAVEN,T SEEN ANY.
ChadS
12-05-2005 08:49:50
 Re: PULLIN FUEL in reply to VETTE, 12-05-2005 07:52:53
Ammoco Ulitmate 93 octane is a good fuel. Run a compression test, if it is under 150psi, 93 is all you need! race fuel wont gain you any power, just cost alot, and smells good out the pipe. But no real good power gain. Chad
Charlie McNelly III
12-04-2005 13:32:09
I think that you would need to look at your compression and the amount of advance you run. Most tractors were made to run on 70 octane when made. Just remember, to much octane is just as bad as not enough. Does it detonate under a heavy load? Fresh fuel helps too. Todays fuel isn't much good after 30 days or so. Good luck.
the tractor vet
12-04-2005 13:25:57
Hightest or what they call hightest a whoppen 93 octain. unless you are running over 10.5 to 1 then that is fine.
vette
12-04-2005 13:44:32
 Re: PULLIN FUEL in reply to the tractor vet, 12-04-2005 13:25:57
THE TRACTOR RUNS FINE AND PULLS GOOD FOR A STOCK ENGINE. I JUST KNOW THAT BACK WHEN IT CAME OUT THERE WAS ONLY LEADED FUEL, SO I THOUGHT I MIGHT NEED SOME KIND OF ADDITIVE FOR EVEN BETTER PERFORMANCE. THANKS, AGAIN
the tractor vet
12-04-2005 14:59:36
 Re: PULLIN FUEL in reply to vette, 12-04-2005 13:44:32
Don't waste your money on the junk that clames to booste power > when we were realy involved in the pullen thing we did a bunch of stuff tryen for just a bit more and unless ya improve comp. change cam grinds and timming and carb work and waste money just for the sake ofwinning a seven dollar trophe and braggen wrights for the next week . I had more fun pullen when we would drop the plow , disc , whatever give the tractor a quick bath load a couple ton of weights on a haywagon and load the kooler with barley pop and go have fun. But nowa days ya have to go after blood and the guy with the biggest check book always wins. Well almost always.
VETTE
12-04-2005 18:54:28
 Re: PULLIN FUEL in reply to the tractor vet, 12-04-2005 14:59:36
WE DON,T EVEN GET A TROPHY, PERIOD, JUST BRAGGIN RIGHTS. I,M JUST HAPPY KEEPING THOSE "GREEN" MACHINES IN THEIR PLACE. LAST, PLACE.
