Sorry for late responce Hugh MacKay
Tom F
12-04-2005 14:00:20
I didnt think anyone replied to my remote valve questions a week or so ago. I dont have a pc at home and I use my in-laws pc when I get a chance.
My super M has the belly pump and I dont really have any current need for the remote attachment but I want to install the assy. during restoration of the tractor. When I get the tractor restoration complete, I then plan to look for implements. If any more info. is needed, let me know. Thanks!!!
Hugh MacKay
12-04-2005 14:39:58
 Re: Sorry for late responce Hugh MacKay in reply to Tom F, 12-04-2005 14:00:20
Tom: I really only responded as it was on page 2 with no responce. There are guys on here more up to date than I on the Farmall belly pump system. I do have some experience, but it is 50 years old.
If your tractor has the belly pump system, all you need is plumbing from one of the outlets on side of torque tube to where ever you wish on tractor, for a single action cylinder. You then control the hydraulic function with belly pump control rod.
If you wish double action you then must install a double action control valve. Hook it into that same port on side of torque tube and run a return line back to fill cap of resevoir. You will have to activate pull rod for belly pump system to supply the valve. There are other complicated items you can get into like sepatate valve for remote plus belly pump control for a 3 point hitch. I'll let others with more experience deal with that. After 50 years I may well be out of date, these guys will soon let me know.
