Farmall 300 Hydraulics no fluid advise ???
Jeff Gerbracht
12-04-2005 14:06:17
I recently purchased a 300 wide front for snow plowing and some light farm work. My father had a Case which he bought enw when he started farming. He once told me that he'd always wished he'd spent the extra and got a Farmall. So that's naturally what I went with, that and they're cute (per my wife). Once I got it home and running I couldn't get hydraulics or PTO to work. Finally tracked down a manual which told me where the PTO lever is and where to check the hydraulic fluid. Found out that the hydraulic fluid reservoir is completely empty. Now I wondering how best to proceed. Should I get some fluid and fill 'er up, sell 'er because it'll cost loads to get the hydraulics going again or have a mechanic look into it. Any advise and/or steps to take would be greatly appreciated. Thanks, Jeff Gerbracht Brooktondale, NY
the tractor vet
12-04-2005 14:48:39
 Re: Farmall 300 Hydraulics no fluid advise ??? in reply to Jeff Gerbracht, 12-04-2005 14:06:17
Well since it is bone dry my guess at this point is that the pump ft. seal is out and dumped it into the oil pan Sooooo i guess that just to conferm what i think i would fill it with Hy Trans and see if what i say is true , first check and see where the engine oil level is then fill the hdy. and run it if the engine oil goes up and the hdy. goes down well then yopu can try a new ft seal and maybe if you are real lucky it will hold if your luck runs like mine get a new pump. And all will be well in Whoville.
