SC front steel rims
Keith-OR
12-04-2005 19:29:37
Need to find out what wheels are stock for the SC. Ones on Shawn's SC have 3 cast iron lugs that are rivoted to the steel rim. Need to locate replacement rims as Shawn's are bent. Rims look like someone ran into sopmething mighty hard in it the past. I have a set of rims off of a Case VAC parts tractor that sure look like the rims on SC...Thanks
Keith & Shawn
gene bender
12-05-2005 02:49:36
 Re: SC front steel rims in reply to Keith-OR, 12-04-2005 19:29:37
If you need some give me a buzz. They are harder to find all the time.
ACHodges
12-04-2005 22:18:39
The rims on the VAC are the same. If good enough use them. Craig
Keith-OR
12-04-2005 22:30:40
 Re: SC front steel rims in reply to ACHodges, 12-04-2005 22:18:39
Craig, glad to hear that, cause they sure look the same to me. I even have IH front wheel weights on my running VAC, They fit like they were made for it. Only thing is they have IH cast into them.. And my extra front wheels are exceptional, very little rust, and are not bent anywhere...Thanks
Keith & Shawn
Mel in OR
12-04-2005 22:09:38
Keith,
Check out Farmland Tractor Supply, 32427 Old Hwy 34 in Tangent, Oregon (between I-5 and Corvallis. Phone is 541-928-1646 and web site is www.farmlandtreactor.com. They likely have some as they have lots of letter series parts. Mel
Keith-OR
12-04-2005 22:21:38
 Re: SC front steel rims in reply to Mel in OR, 12-04-2005 22:09:38
Mel, If the rims I discribed are correct for the SC, then the extra I have off of my VAC are the same. I will do a really good comparison tomorrow morn. Just remembered a close friend has a Super C, will go look at it tomorrow....Thanks
Keith & Shawn
