450 2 point - Down Pressure - Pin
Red Raider
12-05-2005 07:04:56
I think I"m missing a pin used to lock the 2 point in place for down pressure. The spool valve is set for up/down pressure, but the bottom link to the cylinder rotates freely. Can you folks tell me how to give me that feature? I need to use an post auger for some stock pens.
the tractor vet
12-05-2005 07:22:42
 Re: 450 2 point - Down Pressure - Pin in reply to Red Raider, 12-05-2005 07:04:56
Yes they did have a pin andif i remember correctly it was a pointed pin with a spring ball and a rod that made it look like a Tee and it went into the bottom hole under the cylinder now i am sure that it is long gone as with most of them so a not sure here either a 5/8th bolt or 3/4 bolt will work , but becareful as it will lift the back of the tractor off the ground and it can break a posthole digger with that kind of force. But it will put it in the ground.
Red Raider
12-05-2005 11:05:14
 Re: 450 2 point - Down Pressure - Pin in reply to the tractor vet, 12-05-2005 07:22:42
That"s what I thought too. Evidently the bracket attached to cyilinder rotates until the pin stops the motion agaist something and down go the lift arms. Thanks for responding.
