34 in Rims vs 38s
Jim Allen
12-05-2005 07:25:59
Why do some older IH tractors have 34 inch tires and others 38s? My 826D is listed as having either (mine has the 34s) but I guess I want to understand the reason why. 38s seem much more common these days. 34 inch wheels are certainly cheaper at sales. Any input, o-Gurus-of-the-Red?
Nat
12-05-2005 08:36:47
 Re: 34 in Rims vs 38s in reply to Jim Allen, 12-05-2005 07:25:59
It was mostly a matter of cost. The smaller tires and rims were less expensive, and IH could pass the savings on to its investors.
If you're on dry ground, the 34" tires are fine. These tractors didn't have much ground clearance with the 34-inchers, and if you get in mud, look out. You're going to bottom out, quickly.
One thing about the smaller tires is that your actual ground speed is much slower than what the tachometer indicates. You probably think you're going great guns with all sorts of extra horsepower... It's the small tires; they have the same effect as running in a lower gear.
Jim Allen
12-05-2005 08:58:30
 Re: 34 in Rims vs 38s in reply to Nat, 12-05-2005 08:36:47
AHA! (Slap!) Shoulda thought of that myself! Now I know why the tach was saying 6mph and my GPS showed about 4.5. I haven't noted any particular performance problems using 34s. Given they have 80 percent rubber, there certainly isn't reason enough to swap.
ChadS
12-05-2005 09:17:36
 Re: 34 in Rims vs 38s in reply to Jim Allen, 12-05-2005 08:58:30
We have a 826 that has 38's,,,, weird looking set of rims,,, was this a conversion IH did? Ive been told that bout all 826's had 34's,,,, They look like a huge pair replicas of a m farmall with a drop center,,, need parts? parting the ol girl out!! Chad
ChadS
12-05-2005 09:17:17
We have a 826 that has 38's,,,, weird looking set of rims,,, was this a conversion IH did? Ive been told that bout all 826's had 43's,,,, They look like a huge pair replicas of a m farmall with a drop center,,, need parts? parting the ol girl out!! Chad
Nat
12-06-2005 06:23:47
 Re: 34 in Rims vs 38s in reply to ChadS, 12-05-2005 09:17:17
Too bad you're probably nowhere near me. A set of step-rims for 34" hubs to run 38" tires is something Dad's been looking for for about 20 years.
P Backus
12-05-2005 09:34:35
Chad, those rims are made that way so they fit on the same cast wheel center (hub) as the 34"s. You can get the same type of rim if you have a tractor with 38"s on originally and you want to go to 42"s. I"m not sure, but I think that meant your tractor came with 34"s. How are the tires on those rims? Many times folks with the old 34"s would want to upgrade to the 38"s that way- it"s an easy conversion.
Paul
ChadS
12-05-2005 10:56:06
 Re: 34 in Rims vs 38s in reply to P Backus, 12-05-2005 09:34:35
They are not a matched set, but little over 50%, 18.4X38's rims are good. We farmed with a 856 for a long time, still have it. Strong ol tractor. Id like to restore the 856 one of these days. It has a cab off a 1066 on it, Id like to put fenders on it someday. Chad
caseyc
12-05-2005 10:26:14
that's what i did to my 766 paul. it had 34" on it and it drove me nuts cause it didn't look right so i got the drop center rims and put 38's on it, much better now!
casey
P Backus
12-05-2005 11:34:31
 Re: 34 in Rims vs 38s in reply to caseyc, 12-05-2005 10:26:14
Yeah, I"ve got three tractors with 34"s on that should be 38"s, a 706, a green tractor and a "brand X". Thing is, the 706 needs many other things first, the green one the tires are so close to the fender now that I"m not sure 38"s would clear, and the Brand X is MFWD, so that might screw up the ratio. I"d kind of like to put 38" straddle duals on the 1640 combine though.
Paul
Opps!
12-05-2005 09:18:32
Sorry bout the double post,,, ChadS
