How much is it to refinish the crankshaft mains?
AndyE.
12-06-2005 10:00:21
I just need a quick estimate. I got some plastiguage and Im about ready to see if they are in spec. They dont look the best and thats why Im asking. Thanks, Andy
Georgia Boy
12-06-2005 18:50:44
 Re: How much is it to refinish the crankshaft main in reply to AndyE., 12-06-2005 10:00:21
My shop charged $180 to grind the shaft and get me new oversize bearings for an A. That shop isn't the cheapest, they're just the best in my area.
old
12-06-2005 11:34:51
If they don't look good them I'll bet they aren't good. If you run your finger nail across them and it feels ruff it need to be reground. Most of the time its around $100-150 to have it done. Just did one on a koler engine and cost less then $30 but your will cost a good bit more. Never a good idea to put new parts in with haveing the crank checked out and at least polished
El Toro
12-06-2005 10:18:34
If they don't look the best you should use a micrometer or have your local machine shop to measure the rod journals. This way they can determine if the crankshaft is egg-shaped and would require it to be ground undersize if it is.
The mains may need to ground too.
Your local auto machine shop can quote an estimate
by phone if rod jouranls and mains need to be ground. They may be able to just polish the shaft and it isn't scored very much. If it's worn .002" under specs you could use .002" undersize bearings on rod and mains. I think some places even have .003" undersize bearings.
Hal
gene bender
12-06-2005 10:33:27
 Re: How much is it to refinish the crankshaft main in reply to El Toro, 12-06-2005 10:18:34
Dont you mean oversize?
El Toro
12-06-2005 10:37:35
 Re: How much is it to refinish the crankshaft main in reply to gene bender, 12-06-2005 10:33:27
They're called undersize even though they may be thicker. Hal
gene bender
12-06-2005 10:07:36
Last one i had ground was 60 for a B.
AndyE.
12-06-2005 10:09:47
 Re: How much is it to refinish the crankshaft main in reply to gene bender, 12-06-2005 10:07:36
Well, If the plastiguage doesnt have good results, Ill have it refinished. Thanks alot, Andy
p.s. thanks for the quick reply
AndyE.
12-06-2005 10:02:36
Oh, and the journals too. Thanks
El Toro
12-06-2005 10:44:42
 Re: How much is it to refinish the crankshaft main in reply to AndyE., 12-06-2005 10:02:36
Our local auto machine shop charges $85.00 for the shaft from a 4 cylinder engine & $100 for the shaft from a 6 cylinder engine with 4 mains. It costs more if it has more that 4 mains. Hal
