F 30
dwag
12-07-2005 07:24:23
Got motor out and pan off. What else is needed to pull crankshaft? Quick, short step by step please. Thanks
F-Dean
12-08-2005 07:23:27
 Re: F 30 in reply to dwag, 12-07-2005 07:24:23
If you haven't yet removed it, remove the clutch. Also, remove the flywheer to make handling the crank easier. (If you are replacing the main bearings, you will have to pull the flywheer.) On the front end, remove everything off the crank shaft -- it goes out the rear.
Nat
12-07-2005 12:08:10
It's not that hard. Just unbolt everything that appears to be holding the crankshaft in, and label each part with where it came from so you know where it belongs when you go to put it back together. Take notes. Take pictures. You'll find out that you're far more mechanically inclined than you originally suspected, or that taking an engine apart is far easier to do than you anticipated.
