Re: OK Mag Gurus
R-cubed
12-07-2005 10:21:56
There's no way that bolting it down would make it quit working, IMHO. If you don't have any other wires connected than the one that sparks on the bench then the only explanation is it ain't turning equally on the tractor. Either you have it upside down and the impulse isn't working or the drive gears are somehow not turning it. Are you using the wire from the coil to test it? Can you hear the impulse working on the tractor?
