Loader for a single-front wheel H
Vin
12-07-2005 16:47:20
I have a 1949 or so Farmall H, which is set up with just one wheel on the front. I need a hydraulic loader for clearing corrals, so my question is this...is it advisable to attach one to this tractor? What kind? Any advice?
gene bender
12-08-2005 02:50:04
 Re: Loader for a single-front wheel H in reply to Vin, 12-07-2005 16:47:20
As long as you arent carring a heavy load with a 5ft wide bucketway up it should work ok. Now if you plan on carring a big round bale way up high like some think they have to do forget it. Loaders are a piece of equipmint that too often get abused its not wide front or narrow but the NUT BEHIND THE WHEEL.
Hayfarmer
12-07-2005 18:10:44
I don't know that I have ever seen a loader o a tractor with a single front tire. I have seen lots of loaders on tractors with narrow fronts and they seem to wrok ok, just try to keep the load centered. Even a widefront tractor can become unstable when operating with the loader raised. If you go to a widefront you definitely want power steering ot a membership at the gym.
Allan in NE
12-07-2005 17:18:15
Vin,
We tried this back in the old days and it doesn't work.
Aside from the things the other fellas have touched on, you'll pop even high-ply tires like crazy.
A single just cannot handle the load you're gonna put it under loading out manure or moving hay.
Allan
old
12-07-2005 17:05:16
My self I woill not have a tractor with loader and a trike front end. And with a single front wheel even the tire would be worked to hard. Find a wide front tractor for a loader.
Sloroll
12-07-2005 16:51:16
Please don't Vin. Narrow fronts are bad enough. A single wheel with a loader, even in expert hands, is dangerous. Find a tractor with a wide front and preferably somewhat low center of gravity.
