h trans lock up
tn terry t
12-07-2005 21:27:50
it all started about a week ago i asked my son (11 yrs old) to hop on the old h amd move it about 75 foot. it moved without any problems as usual ok now two days later went to use the tractor it wouldnt start acted like dead battery so i put the charger on for three hours still no start got to messing with it and found that if you pushed the clutch in it would start just fine long story a little shorter i found that the drive shaft(52945d) had broken several teeth off also that the pto shaft would turn a3/4 round the lock up also when you were turning the pto shaft (engaged) the right brake pedal would move up and down about an inch any ideas? i keep turning the pto shaft back and fourth and it finally came loose. but it will still lock sometimes but is "gratie feeling " any ideas? many thanks terry t all locked up in middle tenn
Andrew Z
12-08-2005 04:02:07
 Re: h trans lock up in reply to tn terry t, 12-07-2005 21:27:50
I agree with river, that you most likly have a bad bearing I had the same thing happen on my H. It occured after I pulled it in the local fair. (I guess 12,000 lbs on the slead was just too much for those 50 year old bearings.) Anyway pull the top cover off and check for play in the bull pinion gear. You have to drop the bull gear to do it. Also check for wear on the gear. YOu can find used ones in a scarap yard. Good Luck Andrew
riverbend
12-08-2005 03:21:38
It sounds like you will have to look inside the gearbox to see what is the problem. When teeth start breaking, usually something is out of position. That and the grating feeling could indicate a bad bearing.
Will the transmission still shift gears ?
tn terry t
12-08-2005 16:33:33
 Re: h trans lock up in reply to riverbend, 12-08-2005 03:21:38
thanks guys and yea it shifts slick as a ribbon i took the plug out to let it drain good last nite maybe i can see some thing well it has a little slop in an axle bearing so its about time to rip the top and get down to it might be a while untill i get it back togather was quoted 198 dollars for inner, outer bearings ,seals and gaskets to repair one axle its gettin a little ruff on the ole pocket book
