international 424
Deacon
12-08-2005 13:05:04
Bought what I thought was 424 international. Tractor starts and runs good. Everything I find so far says these tractors have eight speed trans. This one has four speed. I think it's in the mid 60's but haven't found any 424 with 4 speed.
Any Ideas
George 2
12-08-2005 18:17:58
 Re: international 424 in reply to Deacon, 12-08-2005 13:05:04
Maybe you have a 404.
CNKS
12-08-2005 13:50:55
Hi-Lo lever could be missing. If it is look for a shaft or hole in the trans housing by your left leg.
Tim...Ok
12-08-2005 13:25:22
should be 4 speed with a hi-lo range,giving 8 forward speeds and 2 reverse.. great little tractors..
genep
12-08-2005 13:23:15
I don't want to insult you, but I gotta ask. Does it have hi/lo two speed?
Does it have a data plate with a model number?
Deacon
12-09-2005 05:23:03
 Re: international 424 in reply to genep, 12-08-2005 13:23:15
There is not a place for the high/low lever. When I look at the pic in my shop manual I can see the lever and cast marks on the housing with L an H cast in place. The housing doesn"t look like the one in the manual. It also shows the gears 1 though 4 an Reverse cast in the housing. This tractors battery box is only a few inches from the shifter and shift pattern is sheet metal tab rivited to box.
Model no. (I think) on the left side of clutch housing has the no. 7418J
Nat
12-09-2005 09:16:43
 Re: international 424 in reply to Deacon, 12-09-2005 05:23:03
That's a serial number. The J means it has a rockford clutch.
Can you post a picture? A 4-speed without hi-lo would indicate to me a variant or descendant of the A/B/C lineage, like a 240 utility. Is the shifter between your legs?
Deacon
12-09-2005 09:30:17
 Re: international 424 in reply to Nat, 12-09-2005 09:16:43
Yes Nat, shifter is between legs. I can't think of anything else that stands out about the tractor. I will take some pics and send them first of the week. This is the first itme I have used this board and I'm not sure where the pics need to go. Do I need your address?
jeff311
12-09-2005 19:39:22
 Re: international 424 in reply to Deacon, 12-09-2005 09:30:17
If your battery box is betwen your legs, it's likely a 404, 240 or 504. If the tractor has square rear axle castings, you may have a 504U. If the axle castings are diamond shaped, its a 404 or 240. If the tractor has diamond axle castings and the main engine hood skirts are rippled like a wash board , it's a 240. If the main engine hood skirts are smooth, it's a 404. As I recall, these are the only IH utility tractors with a battery box between your legs that have a 4 cylinder engine after the 300-330. The 504 did have a 5 speed transmission though.
Deacon
12-13-2005 06:23:10
 Re: international 424 in reply to jeff311, 12-09-2005 19:39:22
With all that you've told me and going the our local IH dealer I have learned that it's not 424 but 404. Thanks for the replies
CNKS
12-09-2005 08:19:51
I have never seen a 424, I have spend substantial time with it's "replacement" the 444. It is as Tim described -- I'm not sure you have a 424.
Tim...Ok
12-09-2005 06:11:57
My 424's battery box in over the rear axle housing on the left side,sunk into bottom of fender..
