winter starting a Hydro 86
Nebraska Cowman
12-08-2005 15:45:48
Seems like any time it gets colder than about 10 below it won't start. I left a magnetic heater on the transmission housing tonight in hopes that might help. Besides moving to a warmer clime, anybody have any good ideas?
T_Bone
12-08-2005 22:45:17
 Re: winter starting a Hydro 86 in reply to Nebraska Cowman, 12-08-2005 15:45:48
Hi NC,
Have you checked the injector timing? If it's with-in spec's, try increasing the timing a couple degrees.
I've never tried this on that pictular engine but have used this on other diesels with good results.
T_Bone
Nebraska Cowman
12-08-2005 17:02:02
Nope, it's the 312 but maybe they ain't no better.
Allan in NE
12-09-2005 05:06:33
 Re: winter starting a Hydro 86 in reply to Nebraska Cowman, 12-08-2005 17:02:02
Boy, I dunno Howard,
Sounds to me like you have all the classic symptoms of an engine that is gettin' a little low on wind.
Even at -25, that thing ought to pop after an hour or so on the heater.
I saw one in at the red shop that had the same problems as yours. After they opened it up, every sleeve/piston in it was scored. They told me it was caused from deacceleration with a cold engine during cold temps.
Hope not,
Allan
K.B.-826
12-08-2005 19:55:06
312's should start much better than 310's. Still, a big tank heater will do much better than the freeze plug heater. It would also be a good idea to get your injectors checked out some time soon. A fresh set of injectors is the easiest way to improve cold starting and all-around performance of a diesel.
K.B.-826
12-08-2005 16:07:47
310 diesel? If so, good luck. Best thing besides an overhaul with the late-style pistons would be the highest wattage tank heater you can find. Freeze plug heaters don't do enough for that engine when it's below zero.
Allan in NE
12-08-2005 16:24:20
 Re: winter starting a Hydro 86 in reply to K.B.-826, 12-08-2005 16:07:47
Yep,
I'm just a dumb cowboy, but I agree with that.
My 310 bellyaches to high heaven if it is 40 out. Nature of the beast, I'm told.
Allan
steveormary
12-08-2005 21:51:56
 Re: winter starting a Hydro 86 in reply to Allan in NE, 12-08-2005 16:24:20
I had an external tank heater (1000w)for my 706 german. 310. Used a timer with it. They sure start easier when warmed up a little.
steveormary
