Rebuilt carb this site?
iester
12-08-2005 18:49:05
Does anybody know what they do to thes carbs? And do they meet manufacture spec,Any adj required
RustyFarmall
12-09-2005 06:53:06
 Re: Rebuilt carb this site? in reply to iester, 12-08-2005 18:49:05
iester, can't tell you much about the carbs available from this site, but I can tell you that all remanufactured or rebuilt carbs will require some adjustment. All engines are just a little different from each other, in other words, you could remove a good carb from one Farmall H and install that carb on an identical Farmall H, and you would most likely have to make some adjustments to make it run good. The carburetors that I rebuild are adjusted to factory initial specs, and then need to be dialed in to the tractor they are installed on.
El Toro
12-09-2005 03:44:24
That email isn't correct that I gave you. Here's a toll free number too. Hal 1-800-292-1616
carbkit@wpe.com
El Toro
12-09-2005 03:31:36
Try the Treadwell Carburetor Company at 607-829-8321. Their email is carbkit@wpl.com. Some of the tractor owners have used this company. Hal
