Farmall H Price????????
Adam IH
12-08-2005 19:14:55
Hi guys,
I found this Farmall H for sale and the owner is wanting 2200 for it. He said it runs good, has been converted to 12 volt,its still all original, it hasnt been restored, its a 51,and it has a factory wide front on it and live hydraulics with a belly pump. Although the tires dont look very good all the way around, Id say it needs new tires, front and rear. It does need to be cleaned up alittle bit, and painted, with some minor body work, he is also one state line away from me and I would have to go get it. what do you guys think, is this price good, or should I try to negotiate or keep looking.
James Williams
12-09-2005 16:29:32
 Re: Farmall H Price???????? in reply to Adam IH, 12-08-2005 19:14:55
Ive been to 2 public auctions and seen 2 different H's in fair to good condition bring over 2200$.I dont understand it.Also I rescued a H from a salvage yard and had atleast 2000$ in it.
sammy the RED
12-09-2005 06:31:12
It is NOT "Still Original" if it has live hyd. and 12-Volt.
$2,200.00 is to much for a H that needs work and new tires.
VETTE
12-09-2005 05:56:00
A FRIEND OF MINE JUST BOUGHT AN "H" THAT CAME OUT OF AN ESTATE, ALL ORIGINAL, FENDERS, THE WORKS, FOR $1500.00. $2200.00 SEEMS REAL STEEP TO ME. J.M.O.
old
12-08-2005 21:05:46
Don't know where you are but I have a good running H, still on 6 volts, needs rear tires. Alol I want for it is $850 and that price isn't set in stone.
CNKS
12-08-2005 19:24:44
H's sell for $600-$1500 or so. It might be worth $1800 if in excellent condition, considering the live hydraulics and WFE. No way $2200. I paid that much for a Stage 2 Super H with factory live hydraulics (the ones on that one are aftermarket, likely M&W, for which there are no parts, far as I know) -- also too much, but IH made 390000 H's. You will find MANY more things wrong with it after you buy it, regardless of what the seller says.
PurdueAg
12-08-2005 19:20:51
I'd want to make sure to test drive it good (does it smoke badly? any noise from rear end? play in steering? does it charge even with lights on? check to see if block SN and tractor SN are the same, ask lots of questions, etc.) and look over it carefully and then try to get him under $2000.00 ($1,800?). The fact that it needs new rubber makes his asking price sound a little high to me, but maybe the factory WF is a factor(?).
CNKS
12-08-2005 19:30:51
 Re: Farmall H Price???????? in reply to PurdueAg, 12-08-2005 19:20:51
I posted before I saw yours -- I didn't steal the $1800 from you. I did buy a M several years ago for $750 with a Swartz WFE and live hydraulics, fair tin -- $1800 would be the absolute maximum, there are just too many H's around to pay any more.
Adam IH
12-08-2005 19:36:01
 Re: Farmall H Price???????? in reply to CNKS, 12-08-2005 19:30:51
Thanks Guys, Ill see what I can do as far as negotiating a price, Its very reashuring to hear some other opinions. Thanks!!
Adam
Dick Davis
12-09-2005 03:03:51
 Re: Farmall H Price???????? in reply to Adam IH, 12-08-2005 19:36:01
With new tires all the way around, $1500 would be a little too much, IMHO. Dick Davis
