H farmall governor
Jimmy Tomlin
12-09-2005 14:15:17
I have a H farmall that when you tightn up the screw"s that hold the rod to the carbater it won't do any thing but idle I can loosen up the two screws and then it will start working like it is supposed to.Does any one know what I can do to fix this problem?
RustyFarmall
12-09-2005 14:20:56
 Re: H farmall governor in reply to Jimmy Tomlin, 12-09-2005 14:15:17
Loosen up the two screws at the other end of the tube, where it attaches to the governor, then tighten the screws at the carb, then go back and tighten the screws at the gov. end. Everything will be allowed to line up that way.
