Hydraulic Controls
Tweeter
12-10-2005 11:46:14
Can the hydraulic valves/levers on the right hand side of the seat on a 330U be upgraded to something new (4-position joystick) or are the original needed because of specific mounting to the tractor? The thing is I broke the one aluminum lever off and I am thinking about replacing the two units with a 4-postion joystick or even replacing just on with a 4-postion joystick. Can the old lever be welded?
Hugh MacKay
12-10-2005 14:10:16
 Re: Hydraulic Controls in reply to Tweeter, 12-10-2005 11:46:14
Tweeter: You can anchor either one of your valves in normal lift position then hook the joystick inlet ports to the valve outlet ports. You may find this works more sucessful one way of flow than the other, thus be prepared to try both ways. It may work best with that factory valve in single action mode.
El Toro
12-10-2005 13:11:52
Any welding shop can weld that lever. Hal
