No More Shoes
Dellbertt
12-11-2005 12:10:58
I have a nice 6ft. snow blade on the front of one of my 300U.
Like a lot of farms around, we use parts of the lawn to park vehicles. When snow plowing I occasionally dig up more lawn than I would like. The shoes would dig in too. With the quick snow we’ve had in SW Mich the ground is nowhere near froze and I was digging lawn like crazy when plowing.
All I could do was backblade with no shoes and it worked great but I couldn’t really put the snow where I wanted. So I thought about it a bit and here is the solution I came up with.
I thought about how smooth it worked backblading with no shoes so I thought about welding a back curved piece onto the bottom of the blade but that would dig in when backblading. So what I decided to try was to bolt a 6ft piece of 3in. heavy pipe to the bottom of the plow thinking it would give it a nondigging edge going either forward or back. It works great! And, I have eliminated having to put the shoes on. Going forward it leaves a nice smooth finish just like backblading. Going straight on it works perfect but it does dig in slightly at the edges if I angle the blade too much, I plan on fixing that by welding a cap on each end. And I can remove the pipe whenever I need to dig or move dirt. I just thought of something else. This just might make it easier pushing brush around the burn pile.
Oh well, it’s still a work in progress. Maybe someone smarter could do it better but it works for me.
Dave in CT
12-11-2005 13:12:08
 Re: No More Shoes in reply to Dellbertt, 12-11-2005 12:10:58
Hey that sounds like a pretty robust solution. I need a hover mechanism as well. Does this make the blade a full 3" higher or is that pipe bolted to the bottom but sort of to the back? The reason I'm asking is 3" seems a little high to hover the blade. My needs are such that I need to be able to engage and disengage the hovering. I take it you're not doing any plowing on asphalt. Before this post, I was thinking about doing it with 3" dolly wheels but your solution sounds stronger. Anyone else with an add-on solution to this problem?
Dellbertt
12-11-2005 16:18:54
 Re: No More Shoes in reply to Dave in CT, 12-11-2005 13:12:08
At present I have it bolted to the two shoe holes which puts it a bit behind the blade. I can add spacers to adjust height just like with shoes. You could use a smaller or larger pipe also. But the smaller the pipe the more it will want to dig. I am thinking of trying a 4in. I don"t plow fast so I think it is strong enough. I have a spare edge and thinking about welding the pipe to it to have a solid weld all the way across with several small braces then just change edges in the spring.
I dont do my neighbors concret drive anymore so I want something permanent for my drive. I don"t know if the pipe would hold up with a lot of asphalt plowing. If you go from asphalt to gravel a lot you might want to stay with shoes.
Now I"ve got the idea of making another pipe with a row of old spike tooth drag teeth as a mini brush rake (pusher).
