TD6, MD, WD6, WD9 Air Cleaner interchangeability?
Doc Larry
12-11-2005 15:57:16
If any of you have a MD, WD6, or WD9 parts book, I need to know if the air cleaner screen and baffle assembly (my part number 67120DA) and oil cup assembly (my part number 54265D) from my TD6 are the same as MD, WD6, or WD9..... .
Thanks in advance for the help,
Larry
n9lhm
12-11-2005 18:14:20
 Re: TD6, MD, WD6, WD9 Air Cleaner interchangeabili in reply to Doc Larry, 12-11-2005 15:57:16
My MD parts book shows part numbers 54261D, 54274D, and 67120DA as part numbers for the "housed screen" assembly, with the 67120DA replacing the earlier numbers. The oil cup shows as 54265D. This is from parts manual TC-28D. Brian
