Mangled M
Vintage Lasts
12-11-2005 17:14:38
1940 M with mangled wiring system-Rewiring correctly
Few questions:
Where was the original location of the starter button on a 1940 M?...foot button at bottom of steering column?
Next, according to wiring schematics, it does not show a starter solenoid/relay. Are the battery cables run straight through the starter button?
If anybody has pics of the instrument/control panel around a 1940 year, I'd like to see them.
Thanks
john d
12-11-2005 19:49:03
 Re: Mangled M in reply to Vintage Lasts, 12-11-2005 17:14:38
Will's got it right. There is one other possibility, however, and I don't know if it could apply to your tractor, or not. Some of the old Farmalls came from the factory with a mag, and a crank starter. Battery ignition, starter, etc, were added later when the farmer got tired of hand-cranking the beast. (On an M, that would take just once for me!)
Some of the dealer-or-farmer installed starter switches mounted on a small pad to the left of the steering post. I have a '43 H with that feature.
Will Sick
12-11-2005 17:48:59
THE STARTER WAS ACTIVATED BY A SHORT ROD THAT WENT THRU THE STEERING POST NEAr THE BOTTOM OF THE POST. THIS rod pushed against the switch that was mounted in the rear gas tank support. The batery cable came from the battery to the switch and then to the starter. There was no selinoid.
