Re: Small imported alternator...one wire?
Bus Driver
12-12-2005 04:26:24
The Delco 10SI will fit under the Cub hood without interfering with anything. I did it on my 1960 Cub and have seen two others that were converted. The space is tight. My third mounting bracket design was the one that worked. The belt tensioning bracket was difficult to design and make. But it works well. The very last Cubs, made in the later 1970's, had the Delco 10SI as standard equipment. Those were the "square" hood Cubs.
